It should be the same as the other A8N series motherboards....
When you go into the DRAM settings, and select 400MHz, it is the same as the HTT freq. Select, for example, 333MHz, and you get 333/400=0.83 of the HTT speed. Selecting the other rations (266, 300, 433 etc) gives you a similar thing - ie 433/400=1.08 of the HTT speed.
