how to set ram timing
16 Nov 2011
hi im trying to set my ram up to work at the right speed i have already set the frequency and voltage but cant find the timing. does anyone know how to set it i have a msi z68a-gd55 g3 motherboard and Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800 C9 1600MHz Dual Channel Kit X 2
1600MHz RAM Speed, CAS 9-9-9-27 Timings, 1.65v memory
Memory timings are located in the Overclocking menu and then Under Advanced DRAM Configuration.
I'm not sure that RAM has an XMP profile but if it has you could just enable that and then set the voltage manually.
I see you mention 1.65V but that's too high for Sandy Bridge, Intel recommend 1.5V with a maximum of 1.575V.
You could start out with, say, 1.55V to get things working and then try and lower it towards 1.5V afterwards.
