How to setup m,y Linksys router so i have a static IP?
2 Jun 2003
Nottingham
Hi,
I have a Linksys WAG354G, now i dont want it to give me a new ip every day. What settings do i have to change for it to work?
Depends what side of the router it's getting a dynamic IP - if it's on your internet connection there probably isn't much you can do (other than coughing up for a static IP).
On the LAN side, you could set the router to dish out the same IP to your machine's MAC address.
i just took the easy way and set static ips which i need to port forward to on 3 machines 192.168.1.100 to 192.168.1.102 and then set dhcp to dish out ip addresses for other machines that don't matter from 192.168.1.110 onwards, thus avoiding conflicts
I just set IP addresses on the computers instead of setting up static DHCP on the router.
EDIT: Just had a look (same router as yours) doesnt do static DHCP :confused: :rolleyes:
do this..
start, run
cmd
ipconfig /all
copy these..
ip address
subnet mask
default gateway
dns servers..
now open control panel, network conenctions, go into properties of the tcp/ip connection and type them in :)
to make it easier i'd set it to 192.168.1.123 or similar, you can also set your router's dhcp starting ip (say 192.168.1.105) -which would leave loads free for you to use..
checkout www.portforward.com
