How to setup Tado underfloor heating?
29 May 2022
Berkshire
I have the Tado smart thermostat (wired thermostat) and extension kit (including internet bridge) installed to run my central heating radiator system and hot water in my house. I am having to an orangery/extension built at the rear of my lounge and the plan will be to run under wet floor UFH in the orangery on a separate zone. The manifold of the UFH heating will have its own pump.
I am looking to have the Prowarm 2-port wet UFH installed. Can someone let me know what Tado components I will need and how this should be connected so that I can control the UFH heating totally separately from the radiator central heating system via the Tado app?
Do you really mean totally separate, if so you need another Tado setup, nice and simple. If you mean UFH as a separate zone then you'll need a relay for the pump and what ever Tado uses for the valves.
I probably didn’t explain it well but I want the UFH to be on a separate zone so that I can control the radiator heating system independently from the UFH via Tado. What I am not sure is what additional Tado components I need to buy.
