How to show FPS with Rivatuner 2.06
1-click on cutomise next to you GFX card info.
2-click on hardware monitoring.
3-click on setup in the bottom right.
4-scroll down untill you come across the framerate option then click the check to activate it.
5-highlight framerate then click setup.
6-check the show "framerate in on-screen display box" then hit "run server" OK it, job done.
You must keep the monitoring graph on in the background to show fps in game.
You can also show stuff like the gpu temperature in the OSD by right clicking on it in the monitoring graph and selecting setup and show in on screen display.
Thanks for that, but i just get FPS 0.0 ???? Any Ideas?
this is how i done it...there is also a small plug-in that you can get to monitor your cpu temps.
dont forget you must add all the games that you want monitoring...the above example only adds stalker
