- 27 Jul 2016
Hi all,
I built myself a new gaming rig recently that fits in to the bracket of 'decent' for the budget: AM4, Ryzen 5800X, 16GB, 3070Ti. My overclocking days are long behind me and I'm broadly happy with large, slowish fans for air cooling at stock speeds. The case and cooling I have fit around this ethos.
The main issue I have is the 3070. It's a Gigabyte GV-N307TGAMING OC-8D, bought second-hand from a friend (who can afford a 4080.) Once the fans get past about 60% they get loud and at full tilt they actually drown out my speakers. temps top out at 80-85C under load, so I don't want to just turn them down.
I'm a watercooling virgin, but confident enough to install something if I can find the right bits. but most of what I've seen however appears to be just parts for a larger system. Is there such a thing as a smaller, closed-loop kit for just GPUs, or should I stick with air cooling and just find something quieter than can handle a ~300W TDP?
