how to stop an program asking for permission to run
1 Mar 2024
Leeds
so ever time i turn on my pc the Thermalright app ask's for permission to run, i want it to run.
how do i stop it asking and just let it run
OS: windows 11 pro
You can't, unless you disable UAC which you SHOULDN'T DO
Well, that's simply not true. Whilst it's possible that some inept poor programming from a large software providers Work Experience initiative might simply have fudged desktop UAC interaction (I'm looking at you MSI), it's perfectly possible to have software work without causing UAC to intervene. Whether you'd want to or not is dependent on your risk appetite. Do you trust what the software is doing, are you limiting it to run, rather than patch / update, etc.
OP, you can use Application Control Policies on your system (running Pro or higher) or craftily set the service as an allowed log on type. The service spawns the executable administratively so would bypass UAC.
