How to stop things stretching
4 Aug 2009
Bournemouth, UK
Hi Guys
well my other half has his third monitor setup, and surround gaming is awesome, But how can you stop webpages etc stretching over all three screens, Windows only detects the monitors now as one big screen instead of 3...... I have tried using Ultramon, but that seems to do the same as windows etc
We have 2 monitors plugged into 1 x 480, and one monitor plugged into the other 480, by DVI
Please help guys as its an awesome setup
Thanks
Hay
Right Click and go into Nvidia Control Panel. Then go into set up multiple displays under the display section on the right hand side. I've done this before Surround gaming came out and it was pretty easy so it shouldn't have changed.
OK i have gone into Nvidia CP and Activated all screens which turns off surround....... but now windows detect 3 seperate monitors, so he can work off 3 monitors now, which I know he will be chuffed about, but this option disables SLI is that right?
I guessing you switch back to surround for games etc???
Sorry guys abit of a nOOb at this
Bump!!!!
Is this right????
Also is there a way, that when you switch between surround and active that it remembers the screen order, because everytime I switch I have to put the screens back in the right order, in Nvidia CP, is that away to save the order...... so to speak?
