Hi,
Ok my question to the guru's on here is as follows. I have just built the following spec:
Intel E8500 with artic cooler pro 7, sapphire HD 4850, p5q pro asus, seagate 500gb 32mb cache, elixier 8500+ 2gb, antec 900, 780w modular power supply and a sumsung dvd.
Now it all runs fine but I have not really put it to the test on crysis etc, so I was wondering, how do you tell if all your ram timings and chip voltages have been set correctly by the motherboard due to it all being on auto? Can it set somethings wrong in the default that it thinks would be ok? What about on the GPU as well in the CCC panel?
Any help or advice is appreciated in advance.
