How to tell if a card will output to 2 monitors out of the box
31 Dec 2003
Stoke on Trent
Hi all,
This may sound a bit n00bish but I've not looked at the gpu market for ages, and all I'm after is any AGP card which will output to two VGA monitors out of the box. i.e. its supplied with any necessary leads/converters which enables it to go to two VGA screens.
any help or model numbers appreciated!
:):confused::eek::mad::cool:;):D:o:(
all that have 2x heads will work
most come with dvi to vga adaptors, windows does the rest using nvidia drivers
or look out for some cards with dual link DVI or dms59 connectors (often dell oem), only one connectors but slipptable with an adapter
Sorry for taking over, but i just want to ask a quick question.
I have just bought a new card, to replace the On-Board pap this machine was currently running.
And i was just wondering if there is anyway i can still use the on-board pap to run a second monitor?
Thanks in advance, [Cas]
