How to tell my CPU speed?
21 Jun 2005
I have an i7 I got from OcUK in the bundle which should be at 4.2. However Windows states its 2.67 which is fine. Now I got CPU-Z now unless I'm being thick how do I see if it's 4.2?
Thanks
-edit-
Changed image as that one was huge!
-edit-
By the way encase anyone else reads this and is interested in a OcUK bundle, when I originally got it, it was running at 4.2 just since then I must have done something :)
That bus speed looks ominous, C1E/Speedstep should be changing the multiplier (as far as I'm aware), not the bus clock.
Run a tool such as OCCT or Prime95, get the CPU to 100% load, and then see what CPUz reports as the speed.
The bus speed is at stock, sems you have lost your overclock.
Check the BIOS Overclockers may of saved a profile.
Thanks both of you. Para, I did what you said and saw it only went to 2.8 so knew there is something wrong.
Then going by what RJC said I checked BIOS and for some reason it had changed profile. Loaded up the 4.2 one in there and now
Thank you :)
