How to tell which x800 my card is?
28 Jan 2006
Right, I have had a few X800s over the past 2 years and I can't tell which the one is I have now that I am selling. I don't want to have to open my computer up and plug it in just to find out which model it is. I think it's either a x800xt pe or x850xt. Please help!
No I think you misunderstood! The graphics card is out of the system and I have a new one in there. I don't want to have to open up the case, plug in the old one and install the old drivers just to find out which model it is!
They'll be a series numbers on the reverse side of the card. Put those numbers in and do a google search, that should tell you what you need to know.
There should be a sticker saying "Radeon X800XT" or whatever.
Also consider the cooler (assuming stock): the X800XTs had a single slot solution; the X850XTs had a dual-slot...
