- 12 Feb 2014
- Somewhere Only We Know
Just a quick question, im just wondering how to test 32gb of ram ? ive got a new CPU, a Ryzen 2700, doesn't look like ive won the silicon lottery this time, the best ive managed to push out of it is 4,075 @ 1.425v wont even do 4.1 across all cores, anyway, so far ive passed 12 hours of Prime95 26.6, 12 hours of AIDA stress test, realbench 8 hours, IBT AVX very high setting for 50 passes.
now I know I can use HCI memtest in windows, but, you can only run 1024 with each window, that's 32 windows I would need to open and get right first time then click start on all of them, quite painful I thing, so should I just run the normal dos version of memtest x86, just to be sure of stability or are the tests ive run so far ample ?
