How to unlock 1.35v on a 780- classy
23 Apr 2009
Derby
My mate has just got a 780 classified hydro copper hooked up to a 480 rad
I'm really struggling to get a voltage higher than 1.212 ive use gregs guide flashed the bios hacked msi and still nothing any ideas :confused:
The temps are silly low idle 19-21 on load after 4 hours of bf 4 was 41 so still got miles to go on the thermal front :D
That I did not know is there any way to check it ?
Find the maximum clocks you can run a chosen benchmark at without the voltage tool, then add the voltage tool and see if you can go higher on the clocks without it crashing. If you can you know it's working. Also your temps more than likely will increase if it's working.
sorted it managed 1437 on the core and 3665 on the memory,
But has a weird I kept bumping up the memory till it was maxxed at +1000 but was getting worst heaven scores why is this ?
the last good score I got was 1785.
