Deleted member 6068
Deleted member 6068
I'm wanting to use 2 psu's in my system one will power all my watercooking setup and one will power my system. Problem is how do u wire the second psu to turn on when i turn the main system on ? The only other option it to try amd sorce an old AT Power supply that just turns on with the switch. It does not need to be powerfull as it only needs to power the pump and 3 12cm fans and maybe a couple of devices like hd's amd cdrom's just to relieve my main power supply from powering everything in my system. Are there any guide's anywhere on the net. Thanks steve.
