Hmm ok, I just came across another post on this forum and the majority of people say that 650w should be fine?
No way, not for crossfire 6950s. I use an 850 watt Corsair PSU and that's the absolute minimum I would dare to use, and only because Corsair make the finest quality units.
850W isn't the minimum.
You can get away with a good 650W PSU but it's not ideal.
A good 750W PSU would be nice and comfortable.
I agree that it's not the minimum but I wouldn't be comfortable with it, hence my choice of wording![]()
Your wording suggesed to the OP that they need an 850W PSU when they don't.
If you'd said how you don't dare use anything less than 850W, but that a good 750W will be fine, then then the OP would have a better idea of their choices.
Ok, So I shall get a OCZ 750W PSU and a Corsair 600t with a Corsair H60?
