how to use memtest?
Caporegime
13 Jan 2010
Llaneirwg
when i boot into it from startup on an ISO it says something a long the lines of:
1) version 3.5
2) version 4.0
memtest ready.
but then it gets no further and i cannot press anything.
what's gong on?
yeah and legacy is enabled :\ I don't have a ps2 anywhere. Is the issue the keyboard then? If so I'll give up on it lol
If legacy is enabled then it shouldn't be a problem anyway. Weird! :confused:
Try burning another copy of the ISO?
normally my g15 will not work in bios anyway but my wireless keyboard does, i dont think its the disc that is the problem.
I have used versions back as far as 1.70 recently when testing memory on machines a few years old. The newer versions just add support for the lastest chipset and memory as well bug fixes.
I take it you have unzipped the file and then used a program like Nero to burn FROM ISO not just burn the ISO file to cd/dvd.
