how to watch hi def with 48701gb
Hi-def what?
hi def please? :p
Need to know whether it's tv (DVB-T, DVB-S) or blue-ray etc you're asking about.
You'll need a blu-ray drive + software (usually bundled) and nothing else for that, the gfx should just work fine.
For TV you'll need a subscription of some kind or freesat from what I understand.
If you mean SD content in a HD resolution, you need to tell us the nature of the input source.
you need a high def source, be it bluray, sky+hd, V+HD, FreeSat..
you cant just watch it because you monitor will display the resolution.
