Permabanned
- 28 Dec 2009
- london
How to wire up network cable: Pay an IT guy £20 an hour to do it for you
How to wire up network cable: Pay an IT guy £20 an hour to do it for you![]()
aaargh, how do you sort these cables out to fit in a rj45.
there so small.
i am following the 568-B Wiring method on http://www.lanshack.com/make-cat5E.aspx
but i dont understand the picture of the cable on there. it says blue white/white blue
so is that blue cable with white on it or white cable with blue on it.
One wire will be mainly coloured with a thin white stripe, and the other will be mainly white with a thin coloured stripe. The predominant color will be mentioned first. CAT5 actually tends to have a pair where one wire is a solid colour, and the other is that colour with a white stripe.
Going to work now. Will check thread when I return. Plus it seems very tight trying to push those small wires into the rj45 socket itself.
PS: my RJ45't have a 'load bar'...............is it crucial?
A load bar should make life easier as it keeps the wires in the correct order when you slide the plug on.
wouldnt it be easier if they just made some with screws instead of punch downs. Make life a lot easier.
Plus, I think shops (including ocuk) should state wherever solid or stranded as would help
If you decide to fit wall plates...
The stranded cable you've used isn't designed for IDC terminals. You may get away with it, but you could have problems in the long term.
If you want to install faceplates and keep the existing cable then have a look for CAT5E Keystone couplers (and the matching Keystone faceplates). From the front they look like a standard network port. On the rear they have a another RJ45 socket instead of individual punch downs.
can you give me some idea where to look for these faceplates and keystone couplers please. As mind field out there as I don't know which companies are reliable.
Thanks
right I am now £40 poorer.
100M solid cat5e, 1 rj45 wallplate and box ordered
Only one wall plate? What's going on the other end, or had you previously bought some others? I'm not sure if it has already been mentioned, but the commonly available RJ45 plugs are for stranded cable not solid core (althought they do usually work okay).
Left with 60 meters of stranded cat5e.
Custom length patch cords for life?
Anyone want some ? lol
All kit is compatible with solid core tbh, it's when you WANT stranded you need to look more carefully.
Any RJ45 plug/faceplate or otherwise should take a solid core CAT5e cable fine. I've used solid core for patch leads and to be honest unless you are doing something silly with them they are unlikely to break.
