--== How to wire up HAF X please? ==--
Status
Not open for further replies.
29 Feb 2012
Hi got used haf x and dont know how to wire up the usb and power cables as there is no manual. Anyone got any ideas please. Web site dont have this technical info or i cannot find it.
Thanks blesses
The USB leads will plug into your motherboards spare USB headers, check your motherboard manual for this and the same will go for the Power & Reset Switch.
Case Power LED & HDD activity LED.
Case fans you can connected directly to the PSU or the motherboards fan headers.
It's easy to work out as all you do is follow the circuit board tracks.
JP4 is for for e-sata.
JP3 is for fire wire (IEEE 1394).
JP1 is for Headset/speakers & mic.
Status
