How wil my machine handle FC2 ???
21 May 2008
Lincs
8800GTX - standard clocks
E4500 @ 2.93Ghz
2 Gig PC6400 RAM
1400 * 900 res monitor
Anyone else playing Far Cry 2 on a similar system tell my how it should run?
Can always clock my GPU if needs be!!
Cheers
It runs perfectly on my similar system at 1680x1050. No idea what settings I'm using, whatever is default I guess, but looks great and runs smoothly.
Im so sorry to dissapoint you.
To follow your gist, is there any reason you have to spam the boards with no constructive comments? :rolleyes: :D
Can anyone else make a constructive comment?
Thanks.
Cheers [TW]Fox!
Thanks.
I've seen it running on lesser PCs at higher res well enough so I doubt you'll have any problems unless you go 'all crazy like' with the AA + ultra quality settings.
Runs crap ( 18-25 fps) @ ultra high with 2x aa and 1280x1024.
Runs playable (23-35 fps) @ very high ( some stuff left on ultra) 2x aa and 1280x1024.
Disable AA and fps shoot up too...
My mates seem to play it with a laptop gfx fine ( m8600GT ) so it should run perfectly on lower settings...
Without AA, you'll be able to run it at ultra after knocking the shadows back down to very high, though I'm not too sure if c2q > c2d makes much of a difference.
E4500 @ 2.93Ghz
2 Gig PC6400 RAM
Cheers
Very similar to my spec, and i run it fine with everything on ultra except shadows on very high, and AA on x2 and DX10 :) Runs so much better than crysis. And i run on 1920x1080
My mate is running it on an AMD x2 4200, 1GB Ram and a 1950XTX card and the game runs fine on that - 1680x1050 at medium(ish) settings (havent seen all the details.
I may have to pick it up, as even though it has mixed reviews, so do a lot of games and wouldn't mind something else to play atm.
I have an E6600 at 3.00Ghz, 8800GTX at default clocks, 2GB DDR 6400. So similar to your system.
Play it at 1680*1050, all settings on Very High, with 4xAA. Runs perfectly fine, no slow down at all.
Excellent comments guys!
Thanks very much. Look forward to getting this bad boy installed and under way!
Thanks for your replies :)
