How will This system handle games?
Permabanned
7 Nov 2006
Nottingham
Hey ive just brought the following system for the pricey sum of £100
P4 3.4ghz @ 3.8ghz with HT
1GB Balistix pc4000
6800GT @ ultra speeds
80gb HDD
How will this handle the latest games. for example C&C 3 ... Thanks :)
That's a good price.
did it come with a case, PSU, DVD etc too? If so it's even better.
It should handle C&C3 fine at medium to high settings. :)
Yeh its a complete system with XP home. :)
Depends how fussy you are really regarding C&C 3. If you want it to hold the max (30fps) then you'll need almost everything turned down on bigger skirmish's, on smaller maps you'll get away with medium. If your a really casual gamer and not fussed at all then higher maybe :p
On low detail with the occasional thing on medium i suspect it'll hold 30fps solid.
nice bargain :D
