How would I drain this?
1 May 2013
M28
It's served me well but getting rid so want to drain and remove.
Not that clear but hoses go out of two case grommets to a 240 rad attached to the back of the case.
Once I cut the cable ties holding the res in I can manoeuvre the pump and res free of the case if of any use?
Was thinking of disconnecting the tube connecting the pump to the res, suck then syphon?
