How would I go about modding this case?
17 Jan 2016
Valley of Jade
Years ago I bought this case;
https://www.overclockers.co.uk/cooler-master-elite-330-midi-tower-case-black-ca-155-cm.html
It's been an 'ok' case over the years, though on reflection I should have bought a more expensive one at the time.
I'm thinking about updating some parts inside the case, so I want some more airflow. The side panelh as a fan mesh section on the side, which I use for one of the fans.
I was wondering if I would be able to add 1 or 2 other mesh places? Even without fans I think it would help with clearing the heat from the case.
How would I go about doing that? What kinda tools do I need?
Are there places that do modding panels?
Also are all side panels the same size? If I buy a panel off a modder site already done and just replace my side panel with that?
Thanks for any info you guys can give me!
I used to have a 330, but I swapped to one with the PSU at the bottom and never looked back. You'll have more space to exhaust hot air out of the top when the PSU is in the bottom.
Probs not the answer you wanted, but just my 2p after owning the same.
Thanks mate, no problem.
I just noticed that there is also a max length for cards too. Looks like at some point I need to buy a different case.
