I might be buying the Logitech Z-5500 soon for use with my consoles and DVD-RW. Apparently the sub has to be at least 60 cm away from other electronics as it will damage them otherwise (how much chance does it have of actually doing that?). So I'm pretty stumped as to where I'd put the thing.
Here is a 360 degree of my room (first 3 photos are most important):
http://i29.tinypic.com/24fn58z.jpg
http://i26.tinypic.com/11l1jjo.jpg
http://i25.tinypic.com/2cnzd49.jpg
http://i29.tinypic.com/2ibj5ti.jpg
http://i29.tinypic.com/96epzb.jpg
http://i29.tinypic.com/2di0vpy.jpg
http://i28.tinypic.com/2z67z8y.jpg
If I put the new sub where my current sub is then it will interfere with the DVD-RW and massage chair. What do you think of putting the sub in the space below where my current amp is (though it would still be less than 30cm away from DVD-RW)? There is also a space between the two cabinets (shown in the 1st and 2nd photo).
If this doesn't work out, then can anyone recommend an alternative option for less than £200?
