- 20 Jan 2004
- Fife
Are these stats OK?
/usr/sbin/adslctl: ADSL driver and PHY status
Status: ShowtimeRetrain Reason: 0
Channel: FAST, Upstream rate = 832 Kbps, Downstream rate = 8128 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Fast
Trellis: ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 8.3 12.0
Attn(dB): 30.0 17.5
Pwr(dBm): 19.8 12.5
Max(Kbps): 8672 1132
Rate (Kbps): 8128 832
G.dmt framing
K: 255(0) 27
R: 0 0
S: 1 1
D: 1 1
ADSL2 framing
MSGc: 1 1
B: 255 27
M: 1 1
T: 1 1
R: 0 0
S: 1.0000 1.0000
L: 2048 224
D: 1 1
Counters
SF: 6278248 6278381
SFErr: 557 1422
RS: 0 0
RSCorr: 0 0
RSUnCorr: 0 0
HEC: 404 302
OCD: 0 0
LCD: 0 0
Total Cells: 2045998171 0
Data Cells: 42960987 0
Drop Cells: 0
Bit Errors: 0 0
ES: 556 0
SES: 0 0
UAS: 22 0
AS: 106734
INP: 0.00 0.00
PER: 1.75 1.75
delay: 0.25 0.25
OR: 32.00 32.00
Bitswap: 0 0
Total time = 1 days 5 hours 39 min 23 sec
SF = 6278248
CRC = 557
LOS = 0
LOF = 0
ES = 556
Latest 1 day time = 5 hours 39 min 23 sec
SF = 1197759
CRC = 212
LOS = 0
LOF = 0
ES = 211
Latest 15 minutes time = 9 min 23 sec
SF = 33099
CRC = 6
LOS = 0
LOF = 0
ES = 6
Previous 15 minutes time = 15 min 0 sec
SF = 52923
CRC = 12
LOS = 0
LOF = 0
ES = 12
Previous 1 day time = 24 hours 0 sec
SF = 5080489
CRC = 345
LOS = 0
LOF = 0
ES = 345
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF = 52923
CRC = 12
LOS = 0
LOF = 0
ES = 12
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF = 52982
CRC = 5
LOS = 0
LOF = 0
ES = 5
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF = 52923
CRC = 9
LOS = 0
LOF = 0
ES = 9
Showtime Drop Reason: 0
Last Retrain Reason: 0
Mode: G.DMT
Channel: Fast
Trellis: ON
Down Up
SNR (dB): 8.3 12.0
Attn(dB): 30.0 17.5
Pwr(dBm): 19.8 12.5
G.dmt framing
K: 255(0) 27
R: 0 0
S: 1 1
D: 1 1
ADSL2 framing
MSGc: 1 1
B: 255 27
M: 1 1
T: 1 1
R: 0 0
S: 1.0000 1.0000
L: 2048 224
D: 1 1
Counters
SF: 6278248 6278381
SFErr: 557 1422
RS: 0 0
RSCorr: 0 0
RSUnCorr: 0 0
HEC: 404 302
OCD: 0 0
LCD: 0 0
Drop Cells: 0
Bit Errors: 0 0
ES: 556 0
SES: 0 0
UAS: 22 0
AS: 106734
INP: 0.00 0.00
PER: 1.75 1.75
delay: 0.25 0.25
OR: 32.00 32.00
Bitswap: 0 0
SF = 6278248
CRC = 557
LOS = 0
LOF = 0
ES = 556
SF = 1197759
CRC = 212
LOS = 0
LOF = 0
ES = 211
SF = 33099
CRC = 6
LOS = 0
LOF = 0
ES = 6
SF = 52923
CRC = 12
LOS = 0
LOF = 0
ES = 12
SF = 5080489
CRC = 345
LOS = 0
LOF = 0
ES = 345
SF = 52923
CRC = 12
LOS = 0
LOF = 0
ES = 12
SF = 52982
CRC = 5
LOS = 0
LOF = 0
ES = 5
SF = 52923
CRC = 9
LOS = 0
LOF = 0
ES = 9
