HOWTO: How to Find Help
Permabanned
18 Oct 2002
Huddersfield / Antartica
Many a time in this small Linux forum of ours you will hear a shout of RTFM! Many Linux Gurus get RTFM rage as new users assume that they are some kind of helpline. There is a reason for this, nearly all of the Linux and Unix tools feature a lot of documentation. This is great for the user, as it means you dont have to wait for a more experienced Linux user to help you
This post aims to provide a selection of links to manuals of all sizes and shapes, so that the user does not have to search for them (god forbid the new Linux user having to find the manuals themselves:
The man command
How to use man
Now our first useful resource is the man command, this is used in the following way:
Code:
man <package name>
It can be executed by any Linux user at all Now, man is a command that formats and shows the manual pages for a particular tool, useful huh? Now, man can be used very easily, sometimes however I have people asking me how to exit man, this is very easy, use
Code:
q <enter>
Pressing the down arrow lets you proceed onto the next page, the man pages typically list all the command line switches of the tool, as well as some interesting configuration information.
To test this command out type:
Code:
man man
Now, read on down, this is the full manual page for the man command, it should be split in nice easy to read sections. This is one of the most useful commands on Linux
When to use man
The time when it is ideal to use man is if you have a question such as What is foo-bar and how do I use it? or I wonder if foo-bar can do blah-de-blah. Since all the functions are listed under the man page then you can use its wealth of resources, as well as read the short description of the function. Also the man page should be used as the first resource before starting to look elsewhere.
Internet Resources
General Problems
LinuxQuestions (www.linuxquestions.org) - This is one of the largest Linux specific forums on the internet, you should NOT automatically think that because these are forums then you should post your question, you shouldnt. This forum has the search feature enabled.So, head right up to the search feature and start searching. Some tips for searching are:
  • Use booleans, AND, OR etc.
  • Make your search as specific as possible
  • Search for only words over two (2) characters long
  • Do not search for "linux" or other such generic terms
There are thousands of posts at the site, most of your problems should be covered here. If they're not then
Google - Linux (www.google.com/linux) - The little known Linux section of google. This site covers many areas of the Linux online world and there will be some matches for your search. Follow the same searching tips as above. (You can also resort to the standard google search if you are having no luck, make sure, however that you do include the word "linux" in the search.
Next stop, New York, well - almost, actually freshmeat.net now the chances are that your software will be listed on freshmeat (www.freshmeat.net). Do a search here for the package name, if it is found then try clicking on the "Project Homepage" link, or the Docs link if there is one; have a thorough read of these and see if your problem is listed as a bug, if it is then there isnt much you can do about it, until the next version comes out
Also, if there is a a SourceForge (www.sourceforge.net) link check that they dont have a forum such as the KICQ projects here. Have a read around here, this will most likely be where the developers help out.
Another place to go will be http://www.linux.org/ , down the nav-bar on the left is a documentation link, have a look, have a read and see whether your problem is listed there. If it isnt then you have two options:
OcUK Linux Forum - We're happy to help if you have read the manuals and have tried to research your problem. Make sure your post includes:
  • The version of the software
  • Your current distro
  • How you installed (i.e. via RPM [urgh evil!] or via .tar.gz [use the source luke!]
  • The exact error message that was given when your program crashed/the problem occured. If you have a random crash problem, try running from the terminal (xterm, konsole, gnome-terminal) to see this error.
If we dont know the answer or you would prefer not to ask @ OcUK then try the aforementioned LQ Forums, or the forums of your chosen package.
Because Linux is free, there are only a limited amount of help sources, the software you install requires some work from YOU the user to get working. The many helplines that can be found for Windows dont exist for Linux and therefore you need to try to help yourself before asking frantically.
Linux requires you to put effort in to make your system work properly, I tweak and change my current Gentoo system frequently - and I know I will never have it perfect. If you want a system that works out-of-the-box and you dont want to put any effort in at all - then go back to WIndows and format every 3 months . The OpenSource community requires both developers and users to put effort it..
Enjoy your Linuxing...
/edit - I've written this, and read over it and it sounds like a rant, it isnt a rant, its a guide for new Linux users, a guide to show people HOW to look for their own information, so that they can try to help themselves. I've picked out what I think are the most helpful guides on the internet and elsewhere for you to use. Please dont take it as a rant. If you think there are any more useful sites on the internet/resources please post them below and I'll add them to the guide
/another edit: RTFM stands for Read The Flipping Manual (or Read the ******* Manual)
Hope you find this guide interesting:
Shak
