HOWTO: SETI@Home on Linux
So you want to start SETI on Linux? The best way is to run the Linux client, as it handles VLARS well and gets equally good times.
To set it up you will need the client for that machine. The following clients are available for Linux machines:
i686
i686 with gnulibc2.1: ftp://ftp.cdrom.com/pub/setiathome/setiathome-3.03.i686-pc-linux-gnu-gnulibc2.1.tar]Download [/url]
i686 with gnulibc1: Download
i386
i386 with gnulibc2.1: Download
i386 with gnulibc1: Download
If they are 800mhz+ then you will want the i686 clients. If you dont know about your glibc version. Then just use the gnulibc version 1.
To set any one of these clients up you will need to download the client into your /home directory.
Open up a terminal (xterm, konsole etc)
Then untar the tarball:
You should then see the tarballs contents being unpacked:
I usually move this directory to something better named so it is easier to find:
Now cd into that directory:
To see all the command line switches for SETI you can run:
This will present you with:
I run the client with the arguments -nolock and -email.
This is done by:
You will see:
This presented to you. If you want a new account press 1. if not press 2.
Then input the rest of the details:
Obviously yours will differ to my choices as this is an example.
When you see this in a terminal you're crunching
Now you just need to join TeamOcUK at the links at the top of the forum
If you want it to run on an SMP machine, just use two clients running in different directories. I have:
Enjoy your crunching
Shak
i686
i386
Code:
sh-2.05a$ tar xvf setiathome-3.03.i686-pc-linux-gnu-gnulibc2.1.tar
Code:
setiathome-3.03.i386-pc-linux-gnu-gnulibc2.1/README
setiathome-3.03.i386-pc-linux-gnu-gnulibc2.1/README.xsetiathome
setiathome-3.03.i386-pc-linux-gnu-gnulibc2.1/setiathome
setiathome-3.03.i386-pc-linux-gnu-gnulibc2.1/xsetiathome
Code:
sh-2.05a$ mv setiathome-3.03.i386-pc-linux-gnu-gnulibc2.1 setiathome
Code:
sh-2.05a$ cd setiathome
Code:
sh-2.05a$ ./setiathome --help
Code:
bad arg: --help
options:
-version show version info
-login log in
-countries show list of country codes
-nice N set priority to N
-email send email notification on error
-graphics create shared mem segment for graphics
-proxy hostname:port connect to SH server through specified
proxy server
-stop_after_process stop after current WU - do NOT send result
-stop_after_xfer stop after current WU - DO send result
-verbose print running status
-nolock skip multiple-instance check
-socks_server hostname:port SOCKS proxy
-socks_user name SOCKS user name
-socks_passwd passwd SOCKS password
This is done by:
Code:
sh-2.05a$ ./setiathome -nolock -email
You will see:
Code:
Welcome to SETI@home.
We use your email address to identify you.
Please type:
1 to set up a new account (first-time users);
2 to log into an existing account (returning users).
Your choice (1 or 2):
Code:
Your email address: [email][email protected][/email]
OK to show your email address on the SETI@home web site? (y/n): y
Your name or nickname: blah
OK to show your name on the SETI@home web site? (y/n): y
Your country number: 213
Your postal code: HD2 2HU
Computer location: 0=unspecified 1=school 2=work 3=home : 3
Everything correct? (y/n) y
Code:
All data received.
Scanning data file
Data Info:
Sky coordinates: 15.409 R.A., 19.790 Dec
Recorded on: 2452527.38854 (Mon Sep 9 21:19:30 2002)
Source: Arecibo Radio Observatory
Base Frequency: 1.419931641 GHz
Beginning analysis...
(This is the last message displayed while the client works.
To see progress messages between now and completion of
processing, operate the client with the -verbose option.
You can also see the progress of the client by looking at
the 'prog=' line in the state.sah file.
Code:
/home/shak/seti/seti1/setiathome
/home/shak/seti/seti2/setiathome
Shak
