not sure if anyone uses data protector?
a couple of the servers we're trying to back up are having issues. one is a server which holds file shares for the macs, the other is a fox pro database and file box.
these are the only 2 boxes that do this (we have exchange, sql and file share boxes that work perfectly) but if you go to restore from the backup it does not display the directory structure. yet if you check the backup logs the full 700gb or so has been backed up?
tbh thinking of ditching it and getting arcserve on the case..
