Hp DV 6820
8 Nov 2002
Has anyone got one of these or know if it is any good I saw one today for £499 is that a good price for spec? I really just want one for pictures, tinternet and odd letter etc.
Diagonal Size 15.4 in Max Resolution 1280 x 800
Networking Data Link Protocol IEEE 802.11b IEEE 802.11g
Optical Storage Type Lightscribe DVD+/-R+/-RW OS Provided
Type Microsoft Windows Vista Home Premium
Processor Processor Number TL-60 Type Turion 64 X2 mobile technology
RAM installed Size 2 GB Storage
Hard Drive Capacity 250 GB
Any thoughts ?
seems like a good price, they are a very nice looking laptop and well put together the core2duo versions of these are a hundred quid more or so but if you just doing normal stuff it should be fine.
I thought it was a good price as well although I may of put the processor wrong I am sure it is core2duo if it is even better value. Going to pick one up the afternoon I think;)
unless you can recomend anything better in this price range?
theres the compaq f765 for £379
Processor Type AMD Athlon 64 X2 TK53
Processor speed 1.7
Memory Size 2 GB MB
Memory Type DDR 2
Hard Drive Capacity 200 GB
Optical Drives DVD Super Multi Double Layer
Screen Size/Type 15.4"
Graphics Card Type NVIDIA GEFORCE 7000
Graphics Memory 335 MB
TV-out YES
Sound Type 3D Soundblaster Pro
Wireless Enabled
No. of USB Connections 3
Weight 3.1 kg
Height 254 mm
Width 2570 mm
Depth 3570 mm
Colour BLACK SILVER
£449 Toshiba A300D-13X AMD TL60 200GB HD 2GB RAM INTEL GFX WEBCAM DVD -RW ETC
Dell Inspiron 1525 £399 C2D T5750 2GHZ 120 hd 2gb ram etc
should keep you busy
