HP G5105uk
29 Jun 2017
I have a HP G5105UK PC with the following spec
M2N68-LA (Narra6) motherboard
AMD Athlon 11 X3 440 processor
4GB RAM
Integrated nVidia GeForce 6150SE
I want to get into games like Rainbow 6 siege and GTA 5 on my PC. I have a budget of approx £380 so would appreciate some advice on the best components to upgrade my PC with.
** Do Not Mention Competitors **
but as i'm just getting started i don't really know what i should be buying.
Really appreciate any helpful suggestions.
I was looking at some budget gaming computers do you think this would be okay?
HDCore
Processor Brand Intel
Processor Type Core i5
Processor Speed 3 GHz
Processor Count 4
RAM Size 8 GB
Memory Technology DDR3 SDRAM
Computer Memory Type DDR3 SDRAM
Hard Drive Size 1 TB
Hard Disk Technology hdd
Hard Drive Interface Serial ATA-600
Graphics Card Description nVidia GT 730
Graphics Card Ram Size 2 GB
Hardware Platform Windows
Operating System Windows 10 Home
for the price £359 because i do have quite a low budget.
Your hp would need the phen II x 4 processor as it's a quad and would run better.
This is probably the best you could do for that system along with finding the quad phens
My basket at Overclockers UK:
Total: £323.44
(includes shipping: £10.50)
Your motherboard is only limited to 4gb which you have so you will need more for more efficient gaming in those titles.
Plenty of gaming desktops on the used market for your budget that would play the games really well or depending on your area then a used gaming laptop can be had for 350-400 depending on spec of course.
