- 2 Feb 2008
- Rainham - Kent
HP laptop has like an onscreen power button -settings - file explorer- profile
the problem is its not actually on desktop if you right click on screen nothing happens - also none of the desktop icons are visible?
They wanted startisback on it as they prefer the old way windows looked on w7 but because of this HP software when you press the windows button it doesn't do anything.
I've tried looking at al the hp software installed but can't seem to find anything??
Be great if anyone knows how to disable this on screen menu
thanks
thanks
