HP Microserver Noob
  • Thread starter Thread starter Pez
  • Start date Start date
Pez
Pez
20 Oct 2002
Warwickshire
Hi all.
Looking to replace a 1TB WD MyBook Live NAS with a Microserver fitted with a 3TB red/blue.
Just looking for a few pointers on best way to proceed, and pointing in the right direction if there is a better way of doing this?
My plan is to install Win7/8 and have it running Plex server, and have Dropbox installed to sync important photos/docs in the cloud.
Questions:
• Is there a better OS to install to achieve this?
• I read that it's worth installing the OS on a separate disk (in some cases USB?)
Is there anything else I should be considering?
Thanks in advance! :)
It would be nice to have a separate disk for your OS install just to help keep your data a smidgin safer. Windows (either version) will be just fine and do exactly what you want. If you fancy squeezing a bit more out of you Microserver then have a look at a Linux distro such as Mint which will be a bit lighter on the resources than Windows.
Thanks for the reply.
I've ordered the hardware, and I'll take your advice and throw Win7 on a spare HDD.
I've used Mint before in a VM, so may give that a whirl while I wait for the kit to arrive :)
