anyone know what and if i can fit a 3g card in this netbook? i still use it and find it fine for day to day use but it would be handy if i had a 3g sim built into it?
I got the hp mini 311 and it would not work with ANY WWan card i tried
flashed custom firmware and it will now work with ANY card
Point i am making is if on manufacturer firmware you will have to buy one of their cards and bend over when they charge you
edit:re antenna,i had to take apart the netbook to install my own 3G antenna as mine while it had a sim slot had no WWAN card or antenna
