Permabanned
- 28 Dec 2009
- london
I have a HP dl380g5 with a p800 sas controller card going in to a HP MSA60 with 10x300gb 15k sas single port disks.
Basically I am looking for a way to optimize the speed.
At the moment it definitely appears to be under performing for some reason. I am going to replace the battery on the controller as it needs replacing in a few days as well update the firmware on the controller and the hard drives as recommended by hp support. When copying from one partition to the other on the array it goes at 8mbyte a second and drops to 1.5mbyte a second for a 1gb file transfer. This is obviously not optimal i would expect at least 30mbyte a second.
During the day the drive array is not under that much use, it is under use but not so much that i would expect such a slow performance. Doing tests in the evening has similar problems.
http://h20000.www2.hp.com/bizsuppor...taskId=&prodSeriesId=3302295&prodTypeId=12169
Fairly recently I used windows disk management and diskpart to extend a partition on the array with some of the unallocated space. That went through without any problems, do you think could have caused it?
The msa60 does not come with a web interface you have to configure it all via the controller which is odd for a san.
The back of the msa 60 there is a sas input and output, what would the output before exactly and any tips on how to improve the speed? My boss suggested defragging the DMS filestore partition but I am not too sure if that is a good idea because i think the DMS guy said that you shouldn't defrag the filestore.
MCS) or PMC, the semiconductor innovator transforming storage, optical and mobile networks, today announced that its 6Gb/s SAS RAID-on-Chip (RoC) controllers are shipping on new HP ProLiant Generation 8 (Gen8) servers.
