OcUK Staff
- 23 Feb 2015
- Overclockers UK HQ
Big chungus gets a humungous price cut.
You can grab the chonky boi with a cool £1000 shaved off.
Check it out here and the rest of the HP Monitor range below!
They are all packed with the latest gaming features, look pretty damn sick and have 2 year warranties.
HP OMEN X Emperium 65" 3840x2160 VA 144Hz 4ms G-Sync HDR1000 Ultrawide LED Backlit Gaming Monitor @ £2,498.95 inc VAT https://www.overclockers.co.uk/hp-o...ide-led-backlit-gaming-monitor-mo-00b-hp.html
Display Resolution 3840x2160 4K UHD, Display Size 64.5", Refresh Rate 144Hz, G-Sync HDR, 4ms Response Time, Contrast Ratio , Panel Type VA, BFGD, Quantum Dot, HDR1000, Nvidia Shield, BFGD, Big Chungus
Was £3498.99 NowOnly £2,498.95 inc VAT.
ORDER NOW
HP OMEN X 25 25" 1920x1080 TN 240Hz 1ms G-Sync Widescreen LED Gaming Monitor @ £548.99 inc VAT https://www.overclockers.co.uk/hp-o...-widescreen-led-gaming-monitor-kb-006-hp.html
Display Resolution 1920x1080, Display Size 25", Refresh Rate 240Hz, G-Sync, 1ms Response Time, Contrast Ratio 1000:1, Panel Type TN, Flicker Free, Height Adjust
Only £548.99 inc VAT.
ORDER NOW
HP OMEN X 25F 24.5" 1920x1080 TN 240Hz 1ms FreeSync/G-Sync Compatible Widescreen LED Gaming Monitor @ £349.99 inc VAT https://www.overclockers.co.uk/hp-o...-widescreen-led-gaming-monitor-mo-00c-hp.html
Display Resolution 1920x1080, Display Size 24.5", Refresh Rate 240Hz, FreeSync, G-Sync Compatible, 1ms Response Time, Contrast Ratio 12000000:1 Dynamic, Panel Type TN, Height Adjustable
Only £349.99 inc VAT.
ORDER NOW
HP OMEN 25MX 24.5" 1920x1080 TN 144Hz 1ms FreeSync 2 Widescreen LED Backlit Gaming Monitor @ £198.95 inc VAT https://www.overclockers.co.uk/hp-o...een-led-backlit-gaming-monitor-mo-00d-hp.html
Display Resolution 1920x1080, Display Size 24.5, Refresh Rate 144Hz, FreeSync 2, 1ms Response Time, Contrast Ratio 2000000:1, Panel Type TN, Thin Bezel, Height Adjustable
Only £198.95 inc VAT.
ORDER NOW
HP 27MX 27" 1920x1080 TN 144Hz 1ms FreeSync 2 Widescreen LED Gaming Monitor @ £248.99 inc VAT https://www.overclockers.co.uk/hp-2...-widescreen-led-gaming-monitor-mo-00e-hp.html
Display Resolution 1920x1080, Display Size 27", Refresh Rate 144Hz, FreeSync 2, 1ms Response Time, Contrast Ratio 12000000:1, Panel Type TN, Height Adjustable, Thin Bezel, Ambient lighting
Only £248.99 inc VAT.
ORDER NOW
HP 25X 24.5" 1920x1080 TN 144Hz 1ms FreeSync 2 Widescreen LED Backlit Gaming Monitor @ £198.95 inc VAT https://www.overclockers.co.uk/hp-2...een-led-backlit-gaming-monitor-mo-00f-hp.html
Display Resolution 1920x1080, Display Size 24.5", Refresh Rate 144Hz, FreeSync 2, 1ms Response Time, Contrast Ratio 1000:1 static, Panel Type TN, Height Adjustable
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
