Hi everyone. Just a couple of questions if I may...
I'm going to be buying a HP Pavilion DV2000 off a friend, stock. The specs are below:
What are the capabilitys for upgrading this kind of laptop? Would I be able to put a more powerful Dual core pentium in? (As long as I keep the FSB the same?) Can I upgrade the graphs card, or can this not be done?
Any advice would be great. Thanks.
~Tyno
Code:
Product Name
dv2278ea
Product Number
RZ978EA#ABU
Microprocessor
1.66 GHz Intel® Core™ 2 Duo processor T5500 with Intel® Centrino® Duo Mobile Technology
Microprocessor Cache
Level 2 cache 2 MB
Memory
2048 MB (2 x 1024 MB)
Memory Max
up to 2 GB
Video Graphics
NVIDIA® GeForce™ Go 7200
Video Memory
128 MB of TurboCache™ video Memory
Hard Drive
160GB 5400 rpm
Multimedia Drive
Lightscribe Super Multi DVD Writer (+/-R +/-RW) with Double Layer support
Display
14.1” WXGA High Definition BrightView Widescreen Display (1280 x 800)
Fax/Modem
High speed 56K modem
Network Card
Ethernet 10/100BT integrated network interface
Wireless Connectivity
Intel® PRO/Wireless 3945 802.11a/b/g Integrated Wireless LAN
Bluetooth® wireless networking
Multimedia Features
HP Pavilion webcam with stereo integrated microphones
Sound
Altec Lansing® speakers
3D Sound Blaster Pro compatible sound 16 bit integrated
Keyboard
101 key compatible keyboard
Pointing Device
Touch Pad with On/Off button and dedicated vertical Scroll Up/Down pad, volume control, mute buttons, 2 Quick Launch Buttons
PC Card Slots
One ExpressCard/54 slot (also supports ExpressCard/34)
External Ports
5-in-1 integrated Digital Media Reader for Secure Digital cards, MultiMedia cards, Memory Stick, Memory Stick Pro, or xD Picture cards
1 VGA port
3 USB 2.0 ports
1 IEEE-1394
1 RJ 11 modem connector
1 RJ 45 Ethernet connector
S-video TV out
Remote control infrared port (Remote Control optional)
2 Headphones-out one w/ SPDIF Digital Audio, 1 Microphone-in port
Cable docking connector
Dimensions
23.70 cm (L) x 33.40 cm (W) x 2.60 cm (min H) / 3.90 cm (max H)
Weight
2.43 kg (5.33 lbs)
Power
90 W AC Power Adapter
6-cell Lithium-Ion (Li-Ion) battery
~Tyno
