Hp pavilion g6 help
10 Mar 2013
Rotherham
So I have an I5 1TB 8gb ram laptop 2 years Ish old, works fine however I recently broke the screen and hinge on the casing.
Does anyone know if it's easy enough to replace the casing, the screen looks simple enough for £35 quid and it all works fine minus the above.. That or I'll have to buy another except in below £400 it's not looking good!
very straightforward on one of these. You didn't say if it's a G6-1xxx or a G6-2xxx but both are simple.
If the hinge itself is broken you'll need to separate the top/bottom casing but if it's just the screen and lid plastics you only have to work on the screen part.
I've repaired dozens of both model, just take your time and you'll have no issues.
