HP Pavilion ze4258 - Athlon XP 2200
18 Nov 2003
Hey guys bought a lappy for uni work from bay for 220 inc del, very good condition kinda suprised. it came with 256mb ram and 64 used my gfx card but i got 512mb samsung for £16 and now its smooth!
its got ati on gfx but i'm not sure if i can goto ati site and get their drivers or use HP ones.
I installed Project IGI to test and it looked ok but was slow LOL. just doing fresh install of XP home
General
Recommended Use: Home use
System Type: Notebook
Built-in Devices: Stereo speakers
Width: 32.9 cm
Depth: 27.2 cm
Height: 4.1 cm
Weight: 3.3 kg
Processor
Processor: AMD Athlon XP 2200+ / 1.8 GHz
Data Bus Speed: 266 MHz
Features: PowerNow! technology
Cache Memory
Type: L2 Cache
Installed Size: 256 KB
RAM
Installed Size: 256 MB / 1 GB (max)
Technology: DDR SDRAM - 266 MHz
Memory Specification Compliance: PC2100
Storage Controller
Type: IDE
Storage
Floppy Drive: 3.5" 1.44 MB floppy - integrated
Hard Drive: 30 GB
Optical Storage
Type: CD-RW / DVD-ROM combo
Display
Display Type: 15" TFT active matrix
Max Resolution: 1024 x 768 ( XGA )
Widescreen Display: No
Video
Graphics Processor / Vendor: ATI Mobility Radeon - AGP
Video Memory: DDR SDRAM
Manufacturer's product description
HP Pavilion ze4258 is designed for mobile users requiring an affordable solution. Thinner and lighter than most notebooks, it lets you experience mobility at no premium thanks to its powerful processor, large display and battery-life-saving features. This notebook makes mobile computing pure simplicity with its range of intuitive ergonomic features. Enjoy peace of mind from HP quality.
Audio
Audio Output: Sound card
Compliant Standards: Sound Blaster Pro
Input Device(s)
Type: Keyboard, touchpad
Telecom
Modem: Fax / Modem
Max Transfer Rate: 56 Kbps
Protocols & Specifications: ITU V.90
Networking
Networking: Network adapter
Data Link Protocol: Ethernet, Fast Ethernet
Expansion / Connectivity
Expansion Slots Total (Free):
Memory
1 ( 1 ) x CardBus - type II/III
Interfaces:
Power
Power Device: External
Power Provided: 75 Watt
Battery
Technology: Lithium Ion
Operating System / Software
OS Provided: Microsoft Windows XP Home Edition SP1
Software:
i reinstalled XP home but it says product key incorrect product key when i try to activate it the COA is under the lappy and i used the HP XP home cd
update just called ms to activate and its done
