- 17 Oct 2002
- West Midlands
Greetings, we have an upcoming project which will require the consolidation of two existing servers one being a AD/File/Print and Exchange Server the other being an SQL Server, in addition to this we are looking to provision two Citrix servers hosting 20 clients each. Overall there will be approx 150 network users.
Im currently looking at the DL580 G5 for the project but it has been a couple of years since working with the 500 range and id like to check the details below if someone has had experience with this model.
Server Specification
4 x Quad-Core Intel® Xeon® E7430 Processor (2.13 GHz, 12MB cache, 90 Watts)
16Gb PC2-5300 Memory Configured For Advanced ECC
16 x 146Gb SAS 10K Hard Disks
2 x P400i SAS Controllers w/512 bbwc
Dual Power Supplies
1 x NC382T Dual Port Gigabit Network Card in Addition to two on-board Nic's
In terms of storage i want to connect one of the backplanes to the first P400i controller and the second backplane to the additional P400i controller, i haven’t yet check whether you can split the backplane on this model but i don’t see why it wouldn’t be possible with the concept of internal storage boxes that HP refers to nowadays.
Im looking at provisioning four servers as below:
1st VM - Windows 2003 AD, File and Print
2nd VM - Exchange 2007 and SQL 2005
3rd VM - Citrix Presentation Server
4th VM - Citrix Presentation Server
Im looking at provisioning the storage as below:
First eight drives connected P400i controller configured in Raid 10, Four logical drives created out of this array to act of OS partitions for the four servers each being approx 146Gb each.
Second set of eight drives connected to second P400i Controller, out of this i would create two Raid 5 arrays with 3 Disks in each leaving two as global hot spares. This would give approx two 250Gb logical drives/partitions for both the SQL/Exchange Server and the File/Print server.
Im looking at provisioning the network connectivity as below:
There will be a total of four 1Gbit Nics available, each one will be dedicated to a VM.
Any comments/suggestions welcome, the other scenarios ive been playing with are the C Class Blade system or individual servers. I will also need to find an appropriate backup solution that can either be run of one of the VmWare servers or as a seperate entity.
Regards
Dual Power Supplies
Regards
