Hi, i have an HP Proliant ML310 G5p that wont turn on.. there is an amber standby light lit on the front of the case and the same on the motherboard. so i assume the PSU is ok.. wont actually turn on and no beep codes.. i have reseated all connectors and RAM.. the CPU heatsink is fixed ok. Could it be motherboard or CPU? i think it might be a socket 775 with a xeon inside.. i do have a spare core2duo somewhere tp try.. any ideas?
I will say the heatsink is pretty thick with dust.. it was a pc used for sub station monitoring... but umm nobody monitored, is it possible the CPU has burnt out
