HP S2231a Mini Review
Permabanned
3 Oct 2009
North Wales
Hello, just thought I'd do a quick write up on this monitor which I got for £120.
Its a 21.5" tn panel model, it has dvi and vga outputs and also speakers.
I went from a viewsonic vx2025wm to this and the step up in quality is pretty marked, colours are much more vivid, blacks are pure black.
After a quick calibration with the windows 7 inbuilt tool it looks brilliant, it does need to be calibrated though as by default the gamma would give you a nice tan.
Viewing angles...this has none of the bad points of previous tn models it can be viewed from any angle with no issues.
The styling is pretty no frills, but I didn't lay down £120 expecting something that wouldn't look out of place in the tate modern.
The bezel is quite chunky so possibly not a ideal choice for a cheap and cheerful multi monitor setup.
Basically, this is a great bang for buck monitor that punches way above its low price point.
Only criticism? If you want a bright, gamma heavy screen this is not for you as when you use a lot of gamma with this screen it starts to look washed out.
I use it at night with little room light and its fine for me though.
This has satisfied me greatly and I highly reccomend this monitor.
