- 7 Sep 2014
Hi,
I've just picked one of these up and as there isn't much information online review wise I thought I'd share some observations.
Essentially it seems like an attempt by Microsoft and HP to rival the Chromebook. It has a AMD quad core unit running at 1GHz (E2 3700) which includes an R3 APU. Alongside this is 2GB DDR3 and some sort of 32GB SSD drive.
TL;DR summary:
+ Silent operation.
+ Adequate CPU
+ Nice clean design
+ Above class average keyboard, decent track pad
+ Above average sound.
- Below par screen (others report a blue tint to the screen but I don't notice this on my model)
- A little low on RAM (2GB).
- Not much hard disk space left after windows installed.
- Windows 8.1
This was more of an impulse buy, I've been looking at getting one of the Chromebooks as a cheap linux machine but having seen this I thought it might be ideal.
The nice is nice, in my opinion probably the best looking of the chromebook / netbook price range devices on the the market. The keyboard is surprisingly good, I'm able to type at a decent speed, the feedback is reasonable and the trackpad is a good size and multitouch works well.
Boot up performance is swift thanks to the SSD, and whilst windows seems to perform well with the quad core CPU it's not without the odd slow down here and there, and when multitasking lacks RAM. Ports are decent, a microSD slot for expansion (which you'll need with the limited disk space), 3 USB slots, HDMI and a headphone slot. The audio is strong thanks to HP's beats audio system, though the volume is lacking.
HD video playback seemed fine with CPU usage around 50% when using HD playback on Netflix.
I've not really used it long enough to comment accurately on the battery life.
There's a more thorough review by Notebook Check here
http://www.notebookcheck.net/HP-Stream-14-z050ng-Notebook-Review.128817.0.html
TL;DR summary:
+ Silent operation.
+ Adequate CPU
+ Nice clean design
- Windows 8.1
