Deleted member 138126
Alright folks?
Have just installed my first pair of HP VC Flex-10/10D Modules, and I have a few questions, in case anyone here is an expert.
- Is there any way of assigning server profiles with blades powered on? I'm really disappointed that it's forcing me to power the blades off, as that introduces a massive outage in order to cut over (cleanly remove old switches, install new switches, upgrade new switches firmware, configure, shut down blades, assign server profiles, power on blades, check).
- I am going to have 4 enclosures per datacentre (for now), would you recommend a single domain (max 4 enclosures), or would you recommend a domain per enclosure? I don't currently have budget for the VC Enterprise Manager.
Any gotchas or recommendations that spring to mind?
Thanks!
Thanks!
