HP W2207h
24 Aug 2011
Hi there ive got a HP W2207h and ive been playing on 1680x1050. Since reading on the internet about my monitor it says its full 1080p, so what i was wondering how to i get it at that resolution and im using a dvi cable to hook it up it doesnt come up with the option to change it to 1080p.
Do i need to have it running using a HDMI cable?
No, DVI and HDMI are indentical in what they support resolution wise. I think you might have made a typo and looked up the wrong monitor? The HP W2207h does run at the native resolution if you're using it with 1680x1050.
oright thanks for clearing that up i think i most prob looked at the wrong monitor.
But the strange thing is when i had my ps3 hooked up it ran at 1080p :P but maybe it was lieing.
