HP Z400 PSU pinout help.
6 Mar 2013
Hi i hope someone can help me with this.
So basically the Z400 Psu has a custom pin config that wont work in normal (consumer) ATX boards. Does anyone know if you can connect an adapter either to the Z400 psu,or if i can get an adapter for my VX550 to fit the Z400 board?
I was looking at the X5650 but it's only 2.66ghz base so it's a bit meh imo. I think i'll go with the X5675,or a W3670. Thanks for the adapter link,much appreciated.
