HP Z640 workstation with dual cpu
22 Jun 2009
Norwich
Hello
I have the above workstation with dual xeon 12 core cpus. The second CPU sits in a riser card with it's own ram slots.
The mainboard has 2/4 ram slots filled with ddr4 2400mhz RAM and the riser card has the same, 2/4 slots with the same RAM.
I have 4x 16GB ram sticks which are almost the same spec but 2666mhz instead.
Can I fit them? For example I can keep the two groups separate for each cpu?
Would the faster ram modules just be running at the slower speed to match the others?
Thanks
Hello
Thanks
I was looking at buying one of those boxes, can you tell me how much power it consumes at idle please.?
