- 8 Sep 2015
Hi Guys!
I have some questions as to what Watercooling system I should use for a HP Z800 Specs below....
2 x Xeon X5670 CPU's (1366 socket)
1 x EVGA GTX 980 2.0 ACX (non superclocked version)
My main issue is space and would most likely require a dual bay reservoir and pump and the radiator to be placed externally due to lack of space and modding with the Z800 case. (but if you have any suggestions i'd be grateful) See pics attached.
The main reason for wanting to watercool is because my internal temps are a tad high I believe, and wouldn't want to risk frying the GTX or my CPU's. I do a lot of 3D Rendering and have the system running pretty much 24/7.
I also have an issue with the fan noise on full load, they're way too loud under load so will possibly swap these out for some Noctua fans or something similar.
I appreciate any help you guys can give me!
Cheers,
Jon.
Cheers,
Jon.
