- 15 Jun 2012
-HP Z840 barebones core (supports up to two xeon v3 or v4 processors).
-Two Xeon 18 Core E5 2696v3 processors (total will be 36C/72T)
-3.8 GHz turbo, perhaps can be turbo hacked
-145 W TDP (each)
-8 Channel DDR4 memory kit @ 2133MHz
Very excited about this build. First of all, it's the culmination of HPs research and development of the premier market workstation in it's day, and I think the case is outstanding, with brushed aluminum sides, HP really knocked out of the park. It's built like a tank, but more on that later.
And possibly adding a 360 radiator if stock cooling system needs a boost. It will be very easy to do this if needed. I am using liquid metal on this build because I am going to be undervolting as well and need lower temps to capitalize on more aggressive turboing.
The build consists of two Xeon E5-2696 V3 CPUs, single core turbo of 3.8
Yes, that's a whopping 20 DDR4 DIMM modules and two 2696 v3 CPU
(and 200MHz increase in turbo boost than flagship 2699 v3)
So I can run an 8 channel memory configuration (DDR4 @ 2400MHz)
Liquid coolers are rated for 150W each.
Sick case:
