HPProliant RAID logical drive not enabling.
29 Aug 2019
on my HP ProLiant DL380G6, with a P410i raid controller. during reboots the `logical` RAID0 drive has been flagged as disabled and I cant get it to re-enable.
long story, but I needed to boot an Linux iso so I could wipe the RAID5 drives sepereately and rebuild the RAID5 array - so whipped out the boot disk so I didn't accidentally wipe it, booted from the USB ISO - wiped the RADI5 disks and then through it would be as simple as possing the drive back into the bay and rebooting but when it restarts now I have the your logical disk is now operational `press f2` to re-enable the logical drive.
the boot drive is just a single RAID0 disk, so its not waiting to rebuild.
only problem is I cant seem to press F2, it doesn't recognise it at all. a second bios/boot menu pops up pretty much straight after and I can see to get it to enable the logical drive now... any ideas ?
You can't have a single raid 0 disk..
Does the server have an ILO? You can login to that and set the 'next boot' method.
